2 1/2 months ago my refrigerator was warm and freezer was fine. Replaced the defrost timer and all seemed fine for about 1 month, then the same thing happened. This time replaced the thermostat and watched it for a few days. Everything seemed good, it was defrosting properly. Put it back together and started using it again. Today, a month and a half later, the same darn thing is going on. All I know that's let is the heater. Can the heater be bad if it is defrosting when I put the freezer in defrost mode? Any and all help is greatly appreciated, Tom
You now may have a bad wire connection in the freezer, or an intermittant one.
Thank you for the idea. Do you have any suggestion for were to start checking for a bad connection? Also, your suggestion made me think of another thing that I have not mentioned. When touching bare metal on the frig (such as when removing toe kick) I receive a slight shock. Also when I was cleaning the back and touched the unpainted metal. It doesn't do it all the time. Could this be a sign of a wiring problem. Thanks again, Tom Originally Posted by: richappy  You now may have a bad wire connection in the freezer, or an intermittant one.
Check the grounds in your fridg, case must be connected to the round pin in the power cord.
Also check the heater mounting.
Check the wiring especially where it bends around the frame, could be a wire has lost it's insulation.
A bad ground can also be in the wall receptacle. |
THIS FORUM IS DEAD!!!!!!! |
