freezer coils in back of freezer icing up.do i need to test defrost heater?:(
check defrost timer, defrost heater, defrost thermostat. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle. How to check everything Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
