AppliancePartsPros.com
Appliance Repair Help
Washer Repair
agitator will not spin durring wash cycle and is making a grinding noise
once i noticed I hadn't closed the lid to the machine I closed it so I could wash my load. The washer made a loud grinding noise and the agitator will not spin. What could be the problem. (it will drain the water out but w/ the loud grinding noise):confused: Any help would be appreciated. Thanks
Check out the coupling first of all. It can be broken and cause the noise.
A broken coupling will still let the machine drain.
Washer Repair
