Lee
ag4ix
#1 Posted : Friday, January 4, 2008 7:20:06 AM(UTC)
ag4ix
This washer will not spin, no lock light. I replaced the wax motor with no result. I then found that r11 on the control board was burnt. I need to know the value of this resistor so I can replace it. I had rather replace a ten cent resistor then have to spend $170 for a new board.
ag4ix
#2 Posted : Friday, January 4, 2008 1:37:40 PM(UTC)
ag4ix
I found that the resistor was a base bias resistor for the transistor that operates a small relay on the control board. The transister was open, the relay had an internal short. I then mounted a SPST switch next to the timer knob to operate the wax moter manually. So as long as I remember to turn the switch on when I load the washer, the door will lock and the mechine will spin. Much better then paying $170 out of my social security.
Lee
SF395LEEB igniters on the right side do not work (Oven Repair (including Ranges and Cooktops))
by Joepre 7/28/2019 5:56:31 AM(UTC)
SF395LEEB igniter question (Oven Repair (including Ranges and Cooktops))
by Joepre 7/28/2019 5:54:30 AM(UTC)
Maytag Dryer - Causing me to lose sleep... (Dryer Repair)
by Salmanilla 8/20/2013 6:46:44 AM(UTC)
Maytag jetclean motor shaft sleeve replacement (Dishwasher Repair)
by christopherv 3/11/2013 6:53:40 PM(UTC)
w lee menefee (Dryer Repair)
by menefeesr 3/9/2013 9:18:33 AM(UTC)
water leeking down inside back of frig (Refrigerator & Freezer Repair)
by giantsjim 4/21/2012 4:29:29 PM(UTC)
Bearing sleeve stuck on transmission housing (Washer Repair)
by HandyDan 4/7/2012 8:52:05 AM(UTC)
Instructions for replacing the sleeve & nozzle (Washer Repair)
by anschenkel 2/21/2012 8:47:01 AM(UTC)
Wobblees and bangs in spin cycle (Washer Repair)
by howellsthat 7/12/2011 2:38:43 PM(UTC)
Dishwasher Sleeping (Dishwasher Repair)
by helpme73 6/27/2011 5:50:10 PM(UTC)
leeval (Washer Repair)
by leeval 5/7/2011 5:17:30 PM(UTC)
Friction Sleeve (Dishwasher Repair)
by elayr 3/19/2011 10:59:10 AM(UTC)
Spinner shaft sleeve (Washer Repair)
by jimoto 2/17/2011 12:52:46 PM(UTC)
part number for sleeve over spinner shaft (Washer Repair)
by jimoto 2/17/2011 10:02:40 AM(UTC)
Sleeve over spinner shaft of Maytag Neptune (Washer Repair)
by jimoto 2/13/2011 8:24:19 PM(UTC)
