mcorneal
#1 Posted : Monday, July 20, 2009 8:46:34 AM(UTC)
mcorneal
Our oven stopped working and has a 'F0' code that will not clear. I've shut off power and it worked again for about 20 seconds but the F0 reappeared and it won't reset again. One line of advice is to replace the timer (available-$197), but another says that it may be the touch pad (no longer available). I hate to buy the timer (non-returnable) only to find it's the touch pad. Any advice?
#2 Posted : Monday, July 20, 2009 12:50:54 PM(UTC)
The "F0" error code means:"Function key stuck". The correction recommended by the manufacturer is to replace the touch pad first and, if it would not help, then replace the control board (aka timer).
The touch pad has been discontinued by the manufacturer. Looks like it's a time for a new range.
mcorneal
#3 Posted : Monday, July 20, 2009 12:56:37 PM(UTC)
mcorneal
Darn it! And it's only lasted 27 years!
I did read somewhere that if I disconnect the touch pad and reconnect the timer and the timer doesn't work, that it might only be the timer that's bad. True?
#4 Posted : Monday, July 20, 2009 1:50:18 PM(UTC)
You can try your luck. Hope dies last.
mcorneal
#5 Posted : Monday, July 20, 2009 2:12:38 PM(UTC)
mcorneal
Thanks! I'll give it a shot.
#6 Posted : Monday, July 20, 2009 7:52:46 PM(UTC)
mcorneal
#7 Posted : Wednesday, July 22, 2009 7:50:34 AM(UTC)
mcorneal
Well, I re-connected the timer without the keypad and it powered up. I re-set the clock, plugged the keypad back into the timer and 'presto' it worked. The oven came on using the keypad and I walked away for several minutes. Upon return, the 'F0' code had reappeared and the oven shut down. Do you still think that the keypad is toast?
#8 Posted : Wednesday, July 22, 2009 12:06:41 PM(UTC)
Most likely the problem is a bad touch pad. There is very small chance for the control board to be bad in such situation.
