Can not find model# looked everywhere. I have a frigidaire dishwasher on the pump motor assembly there seems to be a weep hole on it, it's leaking all the time p/n 154648101 is there a way to repair this or?
If it's leaking then most likely the pump & motor assembly has to be replaced. The model number should be on the door frame. - The pump & motor assembly Part number: AP4339163
Thank you for the help. I've looked on the top both sides took the face of and still can't find the model#
