keisaiguy
#1 Posted : Monday, July 20, 2009 7:06:27 AM(UTC)
keisaiguy
Three weeks ago in response to the door popping open mid-cycle, I bent down the strike (AP3885607) to the point that it lightly contacts the bottom of the latch (AP3179951) when I close the door.
This action gave me satisfactory results through a number of cycles, but now the door has resumed popping open mid-cycle most of the time.
Is it likely that replacing the latch (AP3179951) will solve this problem for a year or so?
Should I replace the strike (AP3885607) at the same time?
#2 Posted : Monday, July 20, 2009 7:09:07 PM(UTC)
I would replace both the door latch and the door strike.
