laudavenpo@aol.com
#1 Posted : Sunday, July 19, 2009 6:03:57 AM(UTC)
laudavenpo@aol.com
my frig is leaking water inside behind the light which is located in top ceiling . Every thing works great . Just tired of having bowl in middle of shelf to catch water. Can anyone help me with this?
#2 Posted : Sunday, July 19, 2009 6:16:21 AM(UTC)
I assume you have a frozen drain in the freezer above the fridg. Just remove the freezer panels and use a turkey baster and hot water to clear out the drain. You can add a drain heater with a 12 gauge copper wire wraped around the defrost heater and 2 inches down the drain.
