daviddep
#1 Posted : Saturday, July 18, 2009 10:24:54 PM(UTC)
daviddep
Our freezer is not cooling. There is power to the unit as the door light comes on. We accessed the evaporater fan motor, it spins freely, so it's not jammed up or anything. (It was replaced five years ago.)
there is no sound coming from the unit. Can't hear the comperssor or anything.
Where do we start to troubleshoot with the ohm meter?
#2 Posted : Sunday, July 19, 2009 1:56:28 AM(UTC)
Need model #
daviddep
#3 Posted : Tuesday, July 21, 2009 8:53:54 AM(UTC)
daviddep
Coldspot frostless 17
if you need more specific, i can search the back of freezer.
thanks
#4 Posted : Tuesday, July 21, 2009 10:32:04 AM(UTC)
Look for a defrost timer, probably in the back, probably not advancing out of defrost, just turn the knob till it runs. Order a new one from the number printed on it.
daviddep
#5 Posted : Wednesday, July 22, 2009 5:24:03 PM(UTC)
daviddep
Found it. says " 3252 service Timer" Part# 482482
Spec# A-931 -00 on back of timer is stamped M8308
do these part numbers seem right?
THe full model of freezer is 106 629440 Serial number F9E150008
by the way- the freezer started working on its own after a couple of days???
#6 Posted : Thursday, July 23, 2009 2:28:39 AM(UTC)
Order a new timer, AP3110896
daviddep
#7 Posted : Tuesday, July 28, 2009 11:40:08 AM(UTC)
daviddep
put in the new timer last night. followed instructions- it appears i have a continous run model. the wires going in are: Pink, Orange, White, black.
so, in put in the timer, advanced it out of defrost, and now hopefully tonight it will go into defrost mode and come out of if it, correct?
thanks.
#8 Posted : Tuesday, July 28, 2009 3:00:51 PM(UTC)
If you hooked it up right it should allways advance, you can mark the housing and the knob to check later.
