bon
#1 Posted : Saturday, July 18, 2009 1:54:50 PM(UTC)
bon
Side by side refrigerator freezer side does not get colder, the frig side works OK.Any ideas?
#2 Posted : Saturday, July 18, 2009 4:47:50 PM(UTC)
Measure your freezer temperature, should be like 10 degrees, if not, remove freezer back panel and describe frost pattern.
bon
#3 Posted : Saturday, July 18, 2009 5:15:53 PM(UTC)
bon
Will check frost and get back to you it is not cold.
fridgproblem3
#4 Posted : Sunday, July 19, 2009 5:32:56 AM(UTC)
fridgproblem3
freezer and frig not cooling frost is build up on the freezer back panial can any one help?
#5 Posted : Sunday, July 19, 2009 7:01:33 AM(UTC)
Your freezer is not getting defrosted. Pull the cover off the motherboard in the back of fridg. Locate the 4 pin power connector and note which pins are labled line and def. Remove the connector and place a jumper between the mating pins on the connector. Plug fridg back in and monitor the jumper current with an amprobe, should be 3 amps and the freezer should defrost. If so, replace the motherboard AP4297272, verify correct part # on the parts list. If no current, you probably have a bad defrost thermostat in the freezer.
bon
#6 Posted : Sunday, July 19, 2009 1:21:24 PM(UTC)
bon
I will give it a try next week thanks
