[FONT="]I have an ancient, built-in KitchenAid KDi - 21AD (installed in 1987). [/FONT] [FONT="] [/FONT] [FONT="]Water doesn't come out of the tube of the upper washer, the main one on the back panel. [/FONT] [FONT="] [/FONT] [FONT="]Water pressure is fine. No leaks under washer.[/FONT] [FONT="] [/FONT] [FONT="]I'm guessing the tube from lower impeller is blocked, but no way to check.[/FONT] [FONT="] [/FONT] [FONT="]Any ideas?[/FONT]
