Hello, New to this forum looking for assistance.Seems like I run out of water on the dispencer, checked flow from wall it seem's okay. Tempeture settings are normal and filter is only a few months old. Is this a reocurring problem with this refidgerator? Thanks for any imput. -Thirsty in CA.:confused:
Check your freezer temperature, may be too cold freezing the water line in the door.
Thanks for reply richappy, the temp settings is set on recommened degree. Hopefully that is the actual tempature at the water outlet point. Still curious if this model has had this problem with anybody else on this forum. Thanks Again, Dan
