Y tube has been discontinued. So this part AP4013715 is supposed to be the answer. It has only one fitting, so you are to bybass the Y and make one line connection. The probelm is this new fitting is 5/16 inch and the tubing is 1/4 inch. Whats up with that? Why would you sell someting that won't work?
You might have a 5/16 to 1/4 inch adapter with the kit, just check. If not, call the parts site. I just replaced one and the new one was 1/4 inch outlet.
