susan2
#1 Posted : Friday, July 17, 2009 9:00:19 AM(UTC)
susan2
We need to replace the water mixing valve but we cant get the washer open. Can anyone help? Would sure appreciate it. Susan2
sidfink43
#2 Posted : Saturday, July 18, 2009 5:17:03 PM(UTC)
sidfink43
Hi Susan
Normally on these you would take off the front panel first. It will either unscrew, or you insert a screw driver in the gap between the front and the top and release two clips that are near the outer edges.
You can then take off the top and access the water valves.
Good luck
