Legend in Your Mind
#1 Posted : Thursday, July 16, 2009 10:03:50 AM(UTC)
Legend in Your Mind
I have a Frigidaire fridge (about 10 yrs old)someone took the relay/capacitor off so I replaced it with one I found in a scrap yard, but the ones I found are the older mechanical types. Should the older mechanicals work as well as the newer black and white deals with the capacitor that plugs in?
I get a loud buzz, but that just shuts off in a minute or less so I'm thinking the compressor is kapootsed or would it it require the newer type relay? I've even reversed the leads..No go.. any ideas?
#2 Posted : Thursday, July 16, 2009 2:11:14 PM(UTC)
Yes, your compressor is probably bad. Only way to be sure is to put the correct start device in, probably not worth spending the money.
Legend in Your Mind
#3 Posted : Thursday, July 16, 2009 2:17:43 PM(UTC)
Legend in Your Mind
That was my thought too.. I might hang on to it to see if I can find the right one, but if not I'll just strip it for parts.. Nice fridge otherwise.. kind of depressing. :/
