2 Pages<12
#11 Posted : Monday, June 6, 2011 2:37:32 PM(UTC)
The complete model number of your dishwasher might help others to help you.
Vern707
#12 Posted : Monday, June 6, 2011 2:43:01 PM(UTC)
Vern707
I have a whirlpool quiet partner iii anf model num is GU2500XTPS3. I was going to install a new heating element yesterday, but after reading this post i started to take mine apart and learned that hot water valve was barely turned on. So i cleared the blinks and turned up the hot water valve and it worked fine. Im going to try it again just to make sure before i return the heating element.
#13 Posted : Monday, June 6, 2011 3:29:32 PM(UTC)
Very often this error code does not mean that anything in the dishwasher is broken. It can be caused by insufficient incoming water temperature or just not enough water like in your case.
Guested
#14 Posted : Friday, April 12, 2024 5:00:36 PM(UTC)
Guest
Rank: Guest
United States
Timeless advice! Our Kitchenaid dishwasher from 2007 threw this clean light blinking 7 times last night. I tried unplugging it and letting it sit, another reset procedure that didn't work, then boom, this did it. Normal - Heat Dry repeat 4 times. All lights will come on hit Start, close the door and voila it's washing. Thank you!!
2 Pages<12
