This dryer has been squeeling intermittantly for about a year. It may go a week or two without the noise, but it is now becomming worse.
I assume, from my on-line research, that it is one of three drum or belt pullies or tensioners. Is there a web site that will give me disassebly instruction so I can inspect the two drum rollers and the one tensioner pulley?
Any other ideas would be appreciated.
Hi RATravis Here is a web site that should help you. Also, if you click on your model number you will be taken to exploded diagrams of your machine. http://www.applianceaid.com/maytag-dryers.htmlSounds like replacing your rollers will solve your problem.
