I have a GE Spectra oven (sorry, I'm at work & don't have the model number). The + (plus) button on the oven touchpad is almost impossible to use. We have to keep pressing all around the button to get it to advance the numbers. All of the other buttons work just fine. What exactly do I need to replace to make it work again?
Thanks!
We have the exact same problem, but it's with the minus "-" button. Have to click all around the button to find the "sweet spot" to make it increment down. The button works if you can just find the right spot, and everything else on the oven works perfectly. Can anyone tell me if it's the touchpad or the full control panel that's at fault?
