Rick Pierce
#1 Posted : Wednesday, January 2, 2008 1:36:38 PM(UTC)
Rick Pierce
GE dryer has power and was working. Went to start the dryer and it will only humm at you when you try to turn the on switch
#2 Posted : Thursday, January 3, 2008 10:40:46 AM(UTC)
Hi Rick,
Most likely the problem with your dryer is a bad motor start winding.
The motor has to be replaced in such case.
- The part number for the motor is AP2043550
- Here are the break down diagrams for the GE dryer Model DWSR485EA1WW
Good luck.
