Mtnman88
#1 Posted : Wednesday, July 15, 2009 5:39:18 PM(UTC)
Mtnman88
Washer does not spin in the spin cycle however it sounds like it is working but nothing moving, I thought maybe a belt broke however I am unable to find a belt, What could the problem be?
sidfink43
#2 Posted : Friday, July 17, 2009 8:56:44 AM(UTC)
sidfink43
Here is a site that will show you how to by pass the lid switch. If it spins then, replace the switch.
Kenmore top loader blues ‎(SublimeMasterJW's Appliance Advice)‎
Since you say it sounds like it is running, a more likely problem is the clutch. If the lid switch is ok, try replacing the clutch.
Good luck
Lsq9110pw3 Won't Spin In Spin cycle (Washer Repair)
by mlmusil01 9/27/2014 2:35:17 PM(UTC)
washer won't spin in spin cycle (Washer Repair)
by siramack 10/7/2012 7:28:20 AM(UTC)
Washer won't spin in spin cycle (Washer Repair)
by LA Stump 4/14/2010 7:13:48 AM(UTC)
by carlous 3/6/2009 6:47:04 AM(UTC)
