snowden207
#1 Posted : Wednesday, July 15, 2009 3:35:23 PM(UTC)
snowden207
Hey all- I replaced the broken coupler on our washer, put it back together and fired it up and BANG!. The dang thing stopped cold.
I flipped it up and rolled the coupler/ motor backwards a few revolutions and tried it again... Bang again. Then I tore it all apart, pulled the pump and motor off and confirmed the problem is on the gearbox/ tranny end of things. Just won't turn forward past a certain point. Any ideas? Sorry I don't have my m/n handy; I'm at work. It's a typical Whirlpool top load direct drive. Thanks.
sidfink43
#2 Posted : Friday, July 17, 2009 8:44:46 AM(UTC)
sidfink43
Hi Snowden
Sounds like the transmission, but I am assuming that when you start the machine it fills with water but will not agitate or spin.
I would suggest you replace the transmission, but if you want more analysis please post your model number and a more detailed description of exactly what happens when you try to operate the machine.
Guest (4)
Whirlpool Washer Locked Up (Washer Repair)
by TLF 3/8/2008 7:37:15 AM(UTC)
