debusk
#1 Posted : 13 years ago
debusk
I need help on tseting my start switch with a digital ohmmeter. I don't think it is working but I need to confirm I am doing it right.
ApplianceJunk
#2 Posted : 13 years ago
ApplianceJunk
The way I would test the start switch with a multimeter is to check the switch for continuity.
I can tell you from experience though that it's never the start switch that is the problem. :)
If the dryer does not start at all I would check the thermal fuse on the back of the dryer. If the dryer does not start, but you can hear the motor humming like it's trying to start then the motor is probably at fault and needs to be replaced.
Just my 2 cents...
GE Dryer turning on without using start switch (Dryer Repair)
by Sinanan 10 years ago
Dryer and buzzer won't stop, start switch is ok (Dryer Repair)
by Thorzdad 10 years ago
All LEDs out, only the start switch works (Dishwasher Repair)
by Jimbo Bigbelly 10 years ago
Dryer start switch wiring (Dryer Repair)
by canifixit14 11 years ago
Maytag dryer will not stay running unless you hold the start switch (Dryer Repair)
by J-Bird-Medic 11 years ago
by duckb0y01 11 years ago
Dryer starts w/o start switch (Dryer Repair)
by jhasr 11 years ago
Replace dryer start switch (Dryer Repair)
by Jpcboca 12 years ago
Dryer runs (without heat) only by holding down Push-to-Start switch. (Oven Repair (including Ranges and Cooktops))
by Reinaldo 12 years ago
Dryer start switch won't stay on. (Dryer Repair)
by liebem 12 years ago
Testing Start Switch Continuity- Which Prongs? (Dryer Repair)
by socrjul 13 years ago
Dryer will not start. Need help with 3 terminal start switch (Dryer Repair)
by EDogzz 13 years ago
Rotary Start Switch (Dryer Repair)
by pdl2 13 years ago
Must continue to hold start switch to operate dryer (Dryer Repair)
by ABCh 13 years ago
Dryer start switch won't hold (Dryer Repair)
by carl Quinto 14 years ago
