m burnell
#1 Posted : Saturday, January 28, 2012 5:35:17 PM(UTC)
m burnell
So the washer would not spin, lid switch ok. Replaced the belt-did a "dry run" test and tub spun. Tried a small load, did not spin out. The motor was running, belt was hot to touch @ pulley-not turning. Advice?:confused:
sidfink43
#2 Posted : Monday, January 30, 2012 5:15:21 PM(UTC)
sidfink43
Sounds like either the transmission, or the brakes which are inside the transmission housing and not a separately repairable item is tghe problem.
m burnell
#3 Posted : Tuesday, January 31, 2012 2:23:35 PM(UTC)
m burnell
Hi Sidfink43,
thanks for the advice....so we tried the $10 fix in high hopes, but you support the other advice I have received. A couple years ago I replaced controls knobs and kept the machine going....just don't make em like they did back then.
Have a great:) day!!
