My oven heats and cooks for a while then it absolutely shuts down . There is nothing lite on the display and no buttons respond, the light in the oven works. After a while the clock will flash like a power failure, but when I reset the controls it goes blank again then I wait to let it cool down and reset and it will cook for awhile again. There has been some sort of code flash but so quickly I could not tell what it was, one time I had 8's across the display briefly. Any suggestions other than a service call? Thanks
Hi Joy
Most likely the problem with your oven is a bad control board.
To find the right part number I need one more digit in the model number (between "A" and "B").
Gene. THANK YOU SO VERY MUCH FOR YOUR RESPONSE. MODEL NUMBER IS JKP15BOA1BB
Hi Joy, The part number for the control board is AP3189149 Good luck. Gene.
