Our oven started acting funny, it would heat up, then once it was hot, beep and flash an F1 error. Then, sometimes it would turn off and cool down, and sometimes it would go into self clean and get super hot. We did some research and found that this was most likely caused by the EOC messing up. We replaced that with this part: FRIGIDAIRE Clock/timer, part number: AP2125571 and now the oven won't heat at all. We double checked the wiring and it's all set up correctly, and the old board will still turn the oven on still, but the new one doesn't. The burners have worked correctly the whole time, it's just the oven giving us fits. Any ideas on how to fix this problem and get me back to baking are greatly appreciated!
