This dryer is being South Africa with 240v 50Hz 15amp service. I'm wondering if the available heater element AP4294403 and thermostat AP2402143 can be used in 50Hz service. Thank you for your time.
my dryer eletric when it gets hot wont run .leave it sit all night it will start up.do you think it might be the motor getting hot kicking off the breaker on the motor?
Originally Posted by: richard morton my dryer eletric when it gets hot wont run .leave it sit all night it will start up.do you think it might be the motor getting hot kicking off the breaker on the motor? when you try to start when its hot just hums and trys to start
