Ryaaa4Christ
#1 Posted : Thursday, January 26, 2012 8:40:44 PM(UTC)
Ryaaa4Christ
Ran washer through many cycles:
1). Cold water will not stop filling when level has been set
2). Cold water used for rinsing fills and stops, rinses during spin, stops when
At end of cycle.
3). Can only wash with hot, cold is turne on when rinse begins
sidfink43
#2 Posted : Sunday, January 29, 2012 7:35:06 AM(UTC)
sidfink43
Normally the problem here is the vaLve is stuck open, but since it will stop ono the rinse cycle the problem is likely with the timer or the temp selection switch.
Try changing out the temp selection switch and if that does not fix things try changing out the timer.
Cold water won't stop running on my Whirlpool Top Loading Washer! (Washer Repair)
by tm3191951 10/17/2009 2:43:34 PM(UTC)
