Hello Gene,
I have a GE profile and am trying to run the self diagnostic check, after holding the FZ FR (2 digit display) I get the 0's flashing. But then what do I do to enter the diagnostic check sequence. I tried entering 0 -7 and they are displayed but then the display lights go off and when I open and close the door they come back on with the temp readings. I dont get any results.
My problem is teh freezer is too cold and teh fridge is warm. I took everything apart and the coil was fully frozen. I used a blow dryer to melt it away put it all back and the fridge started to work again normally for about 4 weeks and now the same problem. Is tehre anything you can tell me to help. Could it be teh damper?
Appreciate your reply. Regards,
John
John,
What is the complete model number of the refrigerator?
