Our freezer continually runs. The temp inside is around -10 to -15 all the time no matter what setting it's on. Would a new thermostat solve this problem??
Groups: APP Team
Hello. First I'll check door gasket. Is it sealing all the way around? If the gasket is OK - then replace the cold control. The cold control Part number: AP2113104
It's not hard to replace it. I'm sorry that your question wasn't answered on time. Although, it's probably too late to help you, I'm posting the answer anyway, so that it may help other people with a similar problem. Thank you.
