Have to keep adding water to all cycles. finally noticed that the water is getting out of the machine long before the cycle is done. can hear water geting into the tub. Something holding the drain valve open, possibly?
entire label reads: model 665-7L972K603 stock 76972K type 5770 serial number FW0804401
