I need to Download a wiring Diagram for my Roper Fridge Can anyone help?
Once I'm able to access the manufactures database again I maybe able to locate one for you. What is wrong with it?
Originally Posted by: ApplianceJunk  Once I'm able to access the manufactures database again I maybe able to locate one for you. What is wrong with it? It wasnt cooling or Freezing and made A clicking sound Got a hard Sart Relay and want to make sure it is hooked up right. Thats why I need a complete wiring diagram.
I would not support you on installing a hard start kit for this modern compressor. The new R134A compressors are not impeadence protected and a hard start kit will blow out the windings, cause a house fire, or burn out the adapive defrost board. Best to install the factory service part specified. The replacement this site has is a AP3108669, a kit with the ptc device and klixon overload. A wiring diagram will not help you to install this. Pry off the compressor cover, make a diagram of which parts whent where and pull the start device out. If it rattles when shaken it's bad. If the parts look just like the ones in the kit, just order the kit, if not, let us know what you have.
Originally Posted by: richappy  I would not support you on installing a hard start kit for this modern compressor. The new R134A compressors are not impeadence protected and a hard start kit will blow out the windings, cause a house fire, or burn out the adapive defrost board. Best to install the factory service part specified. The replacement this site has is a AP3108669, a kit with the ptc device and klixon overload. A wiring diagram will not help you to install this. Pry off the compressor cover, make a diagram of which parts whent where and pull the start device out. If it rattles when shaken it's bad. If the parts look just like the ones in the kit, just order the kit, if not, let us know what you have. I would like the wiring diagram for this fridge can anyone send me this?? I need to make sure all the wires are hooked up correctly.
You need the wiring diagram showing the color of the wires, usually behind the front kick panel.
The Fridge does not have the diagram Thats why I need one!
Can anyone send me the wiring diagram???? It's all I need.
Here is the tech sheet for your model. Hope it helps.
Originally Posted by: ApplianceJunk  Thank You so much!!!
