I am a tech and have a problem with the freezer section of this model. The defrost element tests good. and everything gets cold but the unit never goes into defrost mode. Is there a manual defrost timer somewhere? Or is it in the electronic control up in the fridge? I am not familiar with this model. If it is electronic, is there a way to force it into defrost mode? Or might you expect the defrost sensor attached to the cooling coils? Any info would be greatly appreciated;). Thank you -Michael N & M Services
