skopedia
#1 Posted : Monday, July 13, 2009 1:36:13 PM(UTC)
skopedia
I had a tech look at it and he gave me a list of parts but no part numbers and thats what i need help with please
1 EVAP FAN MTR
1 SUB PBA MAIN
1 SUB FAN-BCKW
Does this list make sense to you as the ones that could be causing the problem?
#2 Posted : Tuesday, July 14, 2009 1:36:23 PM(UTC)
The evaporator fan motor Part number: AP4136569
skopedia
#3 Posted : Tuesday, July 14, 2009 1:42:59 PM(UTC)
skopedia
Thank you for your help. I'll order the parts today.
skopedia
#4 Posted : Saturday, February 13, 2010 4:25:47 PM(UTC)
skopedia
well the sub fan-bckw was not available but the other 2 were and i replaced them to no effect, i ended up defrosting the fridge and checked contiuty on the defrost thermister and it shows continuity at room temprature, does that mean it's bad?
#5 Posted : Monday, February 15, 2010 3:43:21 PM(UTC)
It is important what was the resistance reading and what was the ambient temperature at this time.
skopedia
#6 Posted : Saturday, February 20, 2010 3:32:22 PM(UTC)
skopedia
almost no resistance , was reading 0.1 or o.o most of thw time at room temprature. also like i said before it has continuty.
any ideas?
#7 Posted : Saturday, February 20, 2010 6:16:43 PM(UTC)
At what scale your meter was set?
skopedia
#8 Posted : Saturday, February 20, 2010 8:38:39 PM(UTC)
skopedia
i tried it at 200ohm, 2k, 200k with the same result
#9 Posted: : Saturday, February 20, 2010 11:55:06 PM(UTC)
Sounds like the thermistor is bad.
Guest (4)
