ghettofreddy
#1 Posted : Tuesday, January 17, 2012 6:14:59 PM(UTC)
ghettofreddy
My wife was warming up the oven to 375 when about 5 minutes after turning it on it made a loud pop sound and tripped the breaker. I reset the breaker; the stovetop burners work, the oven light works, but the control with the clock does not come on therefore we can't operate the oven. Is this the control board that needs replaced, or is there a fuse or something else? Thanks.
#2 Posted : Wednesday, January 18, 2012 2:49:44 AM(UTC)
Replacement parts for FRIGIDAIRE FEF366CSB Frigidaire/electric Range | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/p...pringfield/316255311.pdf
I would unplug the unit and try to find out what the pop was.
There will likely be a burn or weld mark.
Check the wiring to the control board.
If all OK then it sounds like the control board is shot.
It does not have a fuse.
