Honusdogus
#1 Posted : Monday, January 16, 2012 6:20:13 PM(UTC)
Honusdogus
I just replaced the control
Ad assembly because oven wasn't working. All good for about two weeks. Suddenly ALL of the burners aren't working, all at the same time. Oven still works though. Any help with which parts I need? Thanks in advance.
jayquinten
#2 Posted : Monday, January 16, 2012 8:52:00 PM(UTC)
jayquinten
it sounds like there may be a couple wires crossed. if there is a wiring schematic on the inside panel some where, i would look that over. most the times them are labeled with a color so you know exactly where they go. and then if everything is in the exact order.....it is very possible that your board is a bad board. electronics can be bad from the start even when you purchase them brand new. hope this helps you out some, if not Thompson Refrigeration Heating & Cooling and i can help you more as i may not be on here daily. good luck!
Honusdogus
#3 Posted : Monday, January 16, 2012 10:20:25 PM(UTC)
Honusdogus
Just checked and all wires are in place. However, I dont believe this assembly controls the burners because they were working when the oven wasn't, but I sure could be wrong. Is there a fuse somewhere that controls the burners, because it kinda acts like a blown fuse. Clock, touchpad and all oven functions are perfect, just no burners work and they all went out at the same time. Thanks again in advance.
tancamper
#4 Posted : Wednesday, May 20, 2015 7:51:22 AM(UTC)
tancamper
Go to the find parts section you will see a exploded view of the range and there is a wiring diagram. I have looked at it and don't remember seeing a circuit breaker but you can check your wiring.
