joseph09
#1 Posted : Sunday, July 12, 2009 11:08:55 AM(UTC)
joseph09
This unit will run fine for sevral days to weeks. Then it will shut down & not restart. If I tap on the thermostat it restarts. My question is can the thermostat be cleaned, repaired or do I have to change it. Thank You
#2 Posted : Sunday, July 12, 2009 3:00:26 PM(UTC)
Remove screws from cold control (1101163) Tap on it to see if the fridg turns off. If you tap on the control mounted, you might be vibrating the defrost timer.
