AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Maytag French door with bottom freezer making noise like marbles rolling around.
Kenmore Elite 25.0 cu. ft. French-Door Bottom-Freezer Refrigerator
Research has shown that noise stops when bottom freezer drawer is opened.
The noise returns when the drawer is closed.
When I open the freezer drawer and push the light switch to turn off the light (as in closing the drawer) the noise stops.
Again, the noise returns when the drawer is closed, light goes off.
Is there something in the light compartment that may be loose?
We are having the exact same issue. Is there a solution? It's extremely annoying! Thanks.
