I have a Whirpool oven RBS305PDB6 and the touch pad on the control panel has gone bad and cannot locate a replacement as it is discontinued. Where can I located the part # 4448471 or is there a substitute. I have seen numerous other Whirpool panels that look similar but do not know if any will work.
Originally Posted by: teegardenj  I have a Whirpool oven RBS305PDB6 and the touch pad on the control panel has gone bad and cannot locate a replacement as it is discontinued. Where can I located the part # 4448471 or is there a substitute. I have seen numerous other Whirpool panels that look similar but do not know if any will work. A company called CoreCentric Solutions refurbs boards. Their web site lists boards they can handle. I used them for my Maytag double oven controller and they had me back up and running in about a week door to door for less than $150 including shipping both ways.
I have already contacted CoreCentric. They have the microcomputer board but do not have or refurb the control panel touchpad.
