jgfraley
#1 Posted : Thursday, January 12, 2012 7:36:30 AM(UTC)
jgfraley
The washer will not go into high spin in any mode. I put it in test mode. Everything worked except the high spin. It will only spin upto around 100 rpm. When the washer call for a high spin it will spin slowly for 15-20 secs ding and stop. Then the pump will run for a couple seconds and the slow spin will start again. It will continue this cycle until you stop it.
Any ideas what the culprit may be?
pestorck@gmail.com
#2 Posted : Friday, January 23, 2015 2:27:47 AM(UTC)
pestorck@gmail.com
I found my washer spinning slowly the next morning. I must have been spinning all night. Any ideas on what to look for?
