Hello guys first off I want to say thanks in advanced for the help, as the topic states my refrig doesn't get cold and the freezer don't freeze I had a tech come to my house today an he took a look at it an said that the "computer" was fried an just so happen to have one on him for $450 after he had my $80 for the service fee, I told him no I'll pass. I removed the back plates I noticed the mb up top an also which I believe is the compressor on the bottom, no frost on the coils an the fan seems to be spinning fine Im very handy so if anyone has any idea what is needed to be replaced I would greatly appreciate it. Thanks again...
How to check stuff> Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.comIs the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan. Are the condenser coils near there warm or room temp. should be warm Below the evaporator fan in the freezer behind the back cover is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
