My Bosch dw continually runs and will not shut off. Also the sray arm will not go around either top or bottom. I have cleaned the filter and took the spray arms off. Couldit be in the circuit board. Also the soap dish willnot open during the long continuous cycle. This started 2 day ago.:confused:
:confused: Originally Posted by: sandra6025  My Bosch dw continually runs and will not shut off. Also the sray arm will not go around either top or bottom. I have cleaned the filter and took the spray arms off. Couldit be in the circuit board. Also the soap dish willnot open during the long continuous cycle. This started 2 day ago.:confused: the serial number is SHX33AO5UC/40
