che
#1 Posted : Thursday, July 9, 2009 10:47:17 PM(UTC)
che
My freezer is as cool as the fridge not freezing or keeping ice cream frozen and my fridge does not keep items cold. what could cause this?
woodchuckie
#2 Posted : Friday, July 10, 2009 5:36:37 AM(UTC)
woodchuckie
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat.Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Part 6 is your timer>http://www.appliancepartspros.com/sect/5/s/9/5s9ds6sbjj.gif
