i have replaced defrost timer.but inside refg is to warm.also alittle ice built up on back panel of freezer compartment.still keeps food frozen.but stops making ice.could this be a thermostst problem along with defrost heater? i have already replaced defrost timer work fine for 3 weeks.not much ice back of freezer panel.
Measure the back freezer temperature and post. Also check the back of fridge and make sure the condensing fan is working, post results.
Originally Posted by: richappy  Measure the back freezer temperature and post. Also check the back of fridge and make sure the condensing fan is working, post results. fan is working fine
Pull out the back freezer panel and check frost pattern, may be defrost failure.
