dryer drum would not turn belt broken but the pulley at the end of te motor was cracked into 2 pcs whic is what broke the belt. im trying to order that pulley and cannot identify it help
Originally Posted by: TITANICHISPANIC ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) dryer drum would not turn belt broken but the pulley at the end of te motor was cracked into 2 pcs whic is what broke the belt. im trying to order that pulley and cannot identify it help aby body help
I do not work for AppliancePartsPros so it is probably best to double check this. Anyway I looked at the parts for this unit. Here is that parts breakdown. Replacement parts for MAYTAG PYGT244AWW DRYER- GAS | AppliancePartsPros.comThere was no motor pulley listed. I then clicked on the motor (Item 1 in Section 5), a new page opens with more views and a Q&A section. The last question in that section was about the pulley and had the following info for a pulley part number. Part number: AP4038987
With luck this is for your machine though I do not see how it is held onto the motor shaft. |
THIS FORUM IS DEAD!!!!!!! |
