jgilje
#1 Posted : Thursday, July 9, 2009 1:58:32 PM(UTC)
jgilje
I just replaced the heating element on my dryer and I can't seem to fiqure what else I can do to get the dryer to dry. The old element looked burned and cracked. Would a try a coil next, any help would be great.
magician59
#2 Posted : Thursday, July 9, 2009 2:09:11 PM(UTC)
magician59
If you can, run the unit and check the temperature as it cycles on and off. If you're getting heat, the most common cause of increased drying time is a restricted or obstructed vent system.
