jcrow
#1 Posted : Monday, January 9, 2012 3:14:34 PM(UTC)
jcrow
Does anyone know how to dis-connect this fastener? (see pix) It connects the door of the microwave to an arm that goes into the frame of the microwave.
jcrow attached the following image(s):
jcrow
#2 Posted : Monday, January 16, 2012 8:14:15 PM(UTC)
jcrow
Just in case anyone else runs into the same problem that I did and finds this post, I found out that the fastener is a pop-rivot. To remove it you must use a small drill bit and then you will need the new rivot (2-piece) parts and the rivot tool to connect it. I had to call a repair service to perform the install. So much for do-it-yourself.
