The model number you posted is incorrect or incomplete. Verify and repost it.
The model number is KSRB25FHSS02 mfg date 01-00. Today I think I heard it trying to move the ice cube release teeth through the ice, but the ice did not release and it stopped.
There is definitely a problem with the ice maker itself and the best solution is to replace it. The new ice maker comes without the front cover, shut off arm and wire harness. You have to use them from the old ice maker. - The ice maker Part number: AP4360346
Your other choice can be the ice maker kit with everything included (almost $40 more). - The ice maker kit Part number: AP2984633
Thanks Gene, I will order the replacement part and give a shout back if I need anymore help!
Gene, the ice maker started working again after I posted, but now there is a drip of water coming from the fill point that caused the ice maker to ice up. Is this in the value or is the system stuck in a cycle where the water value is not quite closed??
Thanks for a reply!
Originally Posted by: heresjohnnyoh  Thanks Gene, I will order the replacement part and give a shout back if I need anymore help!
Thanks for a reply! I ice maker started working again, then after two weeks it iced up. Water kept dripping from the value. I took the valve apart, did not see anything that was clogged, then put it together and the leaking seemed to stop. The ice maker then did not work again, but once. Now the valve is leaking again. This all started after replacing the water filter. Now I have shut off the valve to the water supply so it will not ice up again. Thoughts??
Originally Posted by: heresjohnnyoh  ... Water kept dripping from the value...Now the valve is leaking again... Sounds like the water valve is not closing properly after it was activated by the ice maker. The water valve is not repairable and I would replace it first and watch how the ice maker will work. - The water inlet valve Part number: AP3160649
