jomni
#1 Posted : Wednesday, July 8, 2009 6:42:12 AM(UTC)
jomni
I have a water leak at bottom of door at tubing when you get water from door. need to know if tubing or fitting could be problem inside door and how to replace same
thx
#2 Posted : Wednesday, July 8, 2009 3:47:30 PM(UTC)
You have to inspect the water line tube to find out where it's broke. If the broken spot is 2"-3" from the door then it can be easy fixed. If it's closer to the door or inside the door then it's going to be a lot of headache to fix it. The door has to be removed from the refrigerator and the inner door liner has to be removed.
Here are the breakdown diagrams and Replacement parts for MAYTAG MSD2758DRW | AppliancePartsPros.com
