Washer suddenly gives 'LOC' error and 3 beeps...Door lock switch faulty?
Take out the lower panel and get the service sheet. There is a test for the door lock switch in there. You will need to pull off the door boot, remove the screws from the door switch, disconnect the connectors and pull out and test. If it fails the test just order a new one. To put your boot back on you will need to use super glue at spots where you took it off. Good luck and happy new year!
Tnx, Rich...Did it and switch failed...Have one on order...Was told this is a pretty popular item...
I live in a rural area and mileage additive is $110 to any work done...Tnx again...
Have a Happy New Year!!!
