Judith Yeiser
#1 Posted : Tuesday, July 7, 2009 5:51:46 PM(UTC)
Judith Yeiser
Can someone help me identify the part needed? It is the metal bracket that goes inside the ceramic socket into which the element (burner) cartridge plugs. It is 'u' shaped. It is affixed to a brown wire that connects to the burner control switch with a "jumper" wire that leads off. Basically 2 wires sharing one common end connector spade. The 12" longer wire is soldered to the metal bracket that goes inside the ceramic socket and the shorter wire with a connector end works like a ground.
Dan O.
#2 Posted : Wednesday, July 8, 2009 10:02:35 AM(UTC)
Dan O.
I think the part you're after is in the parts list listed as: Contact/wire assembly (brn)
The "metal bracket" you refer to is the female contact and may look similar to the one at the following link used on older Jenn-Air models.
LINK > Female Cartridge Contact for Older Jenn-Airs
The cartridge contacts for your model however don't look to be available separately.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
